reed switch
quixs1lver
Copper - Posts: 67
Posted: February 23, 2004 at 10:09 PM / IP Logged
i read a lot about adding 'reed' switches around a manual cars shift boot so that a circuit would close when the car was left in gear so that i would not remote start, and i was wondering i did a search on reed switches and came up with a lot of different types, so i was wondering has anyone ever done this, if so how would i got about doing this, i would really like to do this, instead of try to add an extra Neutral safety switch module.
speakerman
Member - Posts: 26
Posted: February 23, 2004 at 10:44 PM / IP Logged
I have done it a couple of times and all it is is a magent and a magnetic switch. You attach the magnets to the acual shifter using glue and then line up the switch part on the outer cover. I usually try and make sure that I get first gear covered and then reverse and then i usually do at least one more. You can space them out to get the other gears but make 100% sure you get those. It is a lot of trial and error with a DMM but better then a car in a wall. I usually hook up the neutral safter wire off the remote start to the e-brake but that is me.
quixs1lver
Copper - Posts: 67
Posted: February 25, 2004 at 11:56 PM / IP Logged
so is that the same magentic switch that goes on sliding doors / sliding windows....when the door/window closed and the contacts are near the switch is open, when they are apart the switch is closed?
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
