alarm/remote start, 1997 acura 2.2cl
bigpimpin18
Member - Posts: 29
Posted: December 09, 2005 at 11:09 PM / IP Logged
hey guys I'm new here, but I am currently trying to install a clifford matrix rsx 3.5 in my 97 acura 2.2CL. I've installed basic alarms and keyless entry systems, and the door lock is not doing very well for me. If anyone has had experience with my type of car please help.
05gt
Silver - Posts: 628
Posted: December 10, 2005 at 12:03 AM / IP Logged
you have to get them in the security module which is under the passenger seat
lock is RED / yellow
unlock is RED / blue
oh yah and you have to meter these wires while turning the key in the passenger door lock cylinder
and you can also get them in the driver kickpanel
lt. blue for lock
BLACK / YELLOW for unlock
bigpimpin18
Member - Posts: 29
Posted: December 10, 2005 at 7:55 AM / IP Logged
awesome thanx, what about the trunk pop. I wired everything up the way they wanted with the relay and it still doesn't work, did you do that?
05gt
Silver - Posts: 628
Posted: December 10, 2005 at 11:03 PM / IP Logged
The trunk release wire at the factory alarm module has to be cut in half
If your alarm puts out a negative pulse trunk release
you need a relay,  pin 87 and 86 goes to a fused 12 volt source, pin 85 goes to the alarm brain, pin 30 goes to the solenoid side of the wire you cut in half, and pin 87a goes to the switch or security module side that you cut in half
if your alarm puts out a postive pulse trunk release
do exactly the same, BUT put pin 86 to negative instead of 12 volts
bigpimpin18
Member - Posts: 29
Posted: December 13, 2005 at 2:10 PM / IP Logged
ok I got all my door locks and trunk solenoid working. Now why isn't my alarm bypassing my stock alarm when it's sitting for a little bit. It just randomly doesn't bypass it. Like over night it was fine, but when i got out of school today my stock alarm wasn't bypassed. I have my GREEN/ black wire hooked up through a relay to my blue wire, which I have been told that's the wire to use to bypass my stock alarm. What should I do, because I can't just take my stock alarm out so how should I got about doing this?
05gt
Silver - Posts: 628
Posted: December 13, 2005 at 2:43 PM / IP Logged
your factory alarm bypasses on lock and unock, I don't know what else to tell you
might have to wait for a better response to this
kgerry
Platinum - Posts: 3,455
Posted: December 13, 2005 at 3:39 PM / IP Logged
you have to interrupt the ign feed to the OEM alarm... usually it's a yellow wire....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
bigpimpin18
Member - Posts: 29
Posted: January 09, 2006 at 7:32 PM / IP Logged
So today I was installing the remote start part of my car and i was thinking if there is a possibility to install the brake shutdown wire on my clutch wires.
My car is a 1997 Acura 2.2CL Manual Transmission
My alarm is a Clifford Matrix RSX 3.5
KarTuneMan
Platinum - Posts: 7,056
Posted: January 09, 2006 at 7:54 PM / IP Logged
See page 5 of your installation manual....alarm/remote start, 1997 acura 2.2cl -- posted image.
dare_ds69
Silver - Posts: 419
Posted: January 10, 2006 at 7:38 AM / IP Logged
use the e-brake to shotdown the car. and use the NSS because it is manual trans.
how own your mind, control your life.
MECP certified. always use a DMM
Page of 3
