Wig-Wag Diagram
chasesaccessori
Copper - Posts: 198
Posted: April 08, 2004 at 2:42 PM / IP Logged
maybe you can add this diagram to your data base.
Wig-Wag Diagram -- posted image.
(owner/installer)
Chase's Accessories
Ridgecrest, CA
in business since 92
the12volt
Administrator - Posts: 3,957
Posted: April 08, 2004 at 3:00 PM / IP Logged
Hi chasesaccessori, will be happy to add a diagram like you have, but I see a problem with your diagram. The lead going to each light should be connected to terminal 30 of each relay respectively, the outputs from the flasher should be connected to terminal 87 of each relay respectively and the switch side of each light should be connected to terminal 87a of each relay respectively. The way it is shown in your diagram now, 12V+ will be sent to the switch side of each light instead of the light itself when 12V+ is supplied by the switch in your diagram.
Wig-Wag Diagram -- posted image. the12volt • Support the12volt.com
the12volt
Posted: April 08, 2004 at 3:01 PM / IP Logged
Ahh, I see you changed your diagram.
the12volt
Posted: April 08, 2004 at 3:03 PM / IP Logged
Your original diagram here was what I was initially replying to.
the12volt
Posted: April 08, 2004 at 3:06 PM / IP Logged
BTW, your second diagram still has a problem. When you attempt to turn on the lights with the switch in the vehicle, 12V+ will be sent to the flasher outputs instead of the lights.
chasesaccessori
Copper - Posts: 198
Posted: April 08, 2004 at 3:42 PM / IP Logged
Your right. Man, I have ht hardest time remembering how relays work unless I have one right here in front of me.
(owner/installer)
Chase's Accessories
Ridgecrest, CA
chasesaccessori
Copper - Posts: 198
Posted: April 08, 2004 at 3:50 PM / IP Logged
here it is correct.
(owner/installer)
Chase's Accessories
Ridgecrest, CA
the12volt
Posted: April 08, 2004 at 5:27 PM / IP Logged
Koo ;)
BumpNGlow
Member - Posts: 43
Posted: April 08, 2004 at 7:43 PM / IP Logged
details on where to get a Terminal Flasher some what cheaply?  Thanks for the diagram.  Is there any easy way to add in a potentometer to make the speed adjustable?  Thanks again
chasesaccessori
Copper - Posts: 198
Posted: April 12, 2004 at 10:13 AM / IP Logged
hope this is better
(owner/installer)
Chase's Accessories
Ridgecrest, CA
Page of 4
Monday, January 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
