Brand new subs, clipping?
lolzitsmtss
Copper - Posts: 174
Posted: September 28, 2004 at 5:46 PM / IP Logged
I have gotten 2 brand new L7's from kicker and they are clipping? what causes clipping?
I guess that guy has subs.
Ravendarat
Platinum - Posts: 2,806
Posted: September 28, 2004 at 5:49 PM / IP Logged
Amps cause clipping and head units cause clipping not subs. Describe what is happening when the system is "clipping"
lolzitsmtss
Copper - Posts: 174
Posted: September 28, 2004 at 5:51 PM / IP Logged
But i went to my installer and he checked the amp and the amp is fine then what he did was try each sub and my right one worked without clipping but my left one didn't. he said the sub is the problem... now could the wire on the left side be bad or neg/pos we bad? its a mono amp...what should i do?
lolzitsmtss
Copper - Posts: 174
Posted: September 28, 2004 at 5:52 PM / IP Logged
It gets to a certain volume and then shuts off then it comes back on with a big bump then shuts off. this only happens on medium volume.. when its low it doesnt clip.
Ravendarat
Posted: September 28, 2004 at 5:53 PM / IP Logged
I am guessing you could have a seperated voice coil on that driver, but ti is not clipping, its cutting out.
lolzitsmtss
Copper - Posts: 174
Posted: September 28, 2004 at 5:55 PM / IP Logged
o..my installer said clipping so thats why i said clipping? what causes it to cut out?
Ravendarat
Posted: September 28, 2004 at 5:58 PM / IP Logged
Like I said, it sounds like a seperated voice coil to me in which case you need to get the sub repaiRED / replaced.
lolzitsmtss
Copper - Posts: 174
Posted: September 28, 2004 at 6:00 PM / IP Logged
even if there brand new? why would they both shut off if only 1 sub is defective? why when i hook only one up it goes to higher volumes. The defective sub cut out at a much higher volume then it usually does..
sorry for so many questions but im just picking your brain now =)
Ravendarat
Posted: September 28, 2004 at 6:19 PM / IP Logged
OK here we go. It is possible that your sub is dead shorting, in which the amp may cut its output until it doesnt detect the short anymore, and since it only happens at high volumes that is why I suggest a seperated voice coil as I have seen quite a few times where the driver will play at low volumes but when turned up it cuts out. It could very easily bee a factory defect right from kicker so thats why I said just take it back and get a new one.
jeffchilcott
Platinum - Posts: 2,483
Posted: September 28, 2004 at 6:35 PM / IP Logged
check to make sure your tinsel leads arnt touching the basket or that your wires are not touching the basket or each other at all
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Page of 3
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
