no HO alt. for me
projectprotege
Copper - Posts: 112
Posted: April 16, 2005 at 3:59 PM / IP Logged
i just called EVERYWHERE in this lovely state(wisconsin) i can think of to find a HO alt for my car...(97 mazda protege LX) and they all told me the same thing....half of the work for the alternator is done by the brain box which i guess is tied in with it...its like the voltage regulator and everything, it is even tied in with the fuel flow management...now this is bogus...im stuck with a puny 70-75 amp alternator and there is nothing i can do about it :( now i have to see if i can even get away with running 2 optima batteries in there with that alt. on my voltage gauge i put in with the system, the car idles at 14.7v and when driving its at 15.1v which i guess is awsome but i still need the extra boost....what do you guys think? think im screwed on this part? lol
DYohn
Moderator - Posts: 10,741
Posted: April 16, 2005 at 5:28 PM / IP Logged
Well, I guess it depends on your plans.  Have you tried Mazda directly to see if they make a "heavy duty" alternator (with all the necessary electronics) for your car?  It'd be a lot of money, probably, if they do make one.  With a 75 amp alt, you should be able to support 300 or so watts of amplifier power without any problem, so you could go for high-efficiency speakers and get decent SPL.  Or, again depending on how much you want to spend, you could have a bracket fabricated and run a second alternator dedicated to your stereo system.  Check with auto electrical or higher-end car stereo shops in your area, or contact Zena and get a quote.
I applaud you for thinking of this and planning your power system.  Far too many people leave this to last and then wonder why their "awesome" system sounds wimpy and kills their battery and sometimes the entire car's electrical system too...
Alpine Guy
Platinum - Posts: 2,478
Posted: April 16, 2005 at 5:54 PM / IP Logged
Thats bull, an alternator is an alternator.  What ever follows after that is just that.  Nothing can actually be attached to the alternator to control your car other than the regulator.
Have you called specialy companys such as www.mechman.com , www.mean-green.com , ohio generator?
jeffchilcott
Platinum - Posts: 2,483
Posted: April 16, 2005 at 5:56 PM / IP Logged
have you tried domonick iraggi.   look for iraggi alts on ebay.   there is only one plan for his 9,999,999 plans   but he has a store if you go into that auction.    also look up ohio generators
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
auex
Platinum - Posts: 5,041
Posted: April 16, 2005 at 8:36 PM / IP Logged
Go get a junkyard alt and have it rebuilt. It shouldn't be a much a problem doing it this way.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
racer427
Silver - Posts: 381
Posted: April 16, 2005 at 9:37 PM / IP Logged
Ok, Off topic here a little bit. I just checked out Iraggi Alts on E-Bay and the seller has a feedback rating of 12 at 92%. And I should buy an alt from them???????????????????
  Chris
Alpine CDA-9833 HU
Diamond Audio M661 Components
MTX Thunder T6.6 Components:rear fill:
Cadence Q400 4 Channel Mains + rears
Thunder 801D Subs
MTX 1004 10's
Dual 4g wire to rear
4g grounds
supradude
Silver - Posts: 915
Posted: April 17, 2005 at 10:08 AM / IP Logged
Yes. He builds some of the best HO alternators around.
'85 Toy
jeffchilcott
Posted: April 17, 2005 at 10:56 AM / IP Logged
Dommonick is one of the best alternator builders in the world!    I would put my name against that.    He just recently started selling on ebay.       He is a large supporter and competitor in the Usaci and DB drag curcuits
2007 World Record
Maxst
Silver - Posts: 866
Posted: April 17, 2005 at 6:57 PM / IP Logged
Just see about getting it- or another one- rewound.
15volts while driving is pretty darn good IMO..
I need quality equipment, feel free to donate.
mad scientst 2.
Posted: April 17, 2005 at 7:01 PM / IP Logged
 Not exactly sure what you're trying to say, but I can say that computer controlled alternators have been in use since at least the mid 80's with Chrysler.. I can state that GM is currently using the ECM to control the alternator (I can hook a scan tool to a GM car and turn the alternator on and off), and a quick google search shows that Mazda is indeed using the car's computer to control the alternator.
 Jim
