2008 chev duramax stock rs
Brad Eyben
Member - Posts: 33
Posted: February 02, 2008 at 12:16 PM / IP Logged
Does anybody know if there is a way to increase the run time for the factory RS on a new Duramax?
It will only run for 10 min and then 1 additional 10 min.
I'm wonder if GM makes there own RS or is it an aftermarket?
Thanks,
Brad
extreme1
Silver - Posts: 1,070
Posted: February 02, 2008 at 2:51 PM / IP Logged
it's neither, it's a firmware upload into the vehicles BCM and a new FOB.
there is no external starter unit in those vehicles. this mean ANY GM vehicle with the new PK3+ setup can be flashed with remote starter software.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Brad Eyben
Member - Posts: 33
Posted: February 02, 2008 at 5:30 PM / IP Logged
Thanks, I guess I'll ask GM but not hold my breath...
KarTuneMan
Platinum - Posts: 7,056
Posted: February 02, 2008 at 6:58 PM / IP Logged
DO hang on to your wallet though!
sparkie
Platinum - Posts: 2,061
Posted: February 02, 2008 at 7:24 PM / IP Logged
There isn't any way to increase the run time. The only thing you can do is to add a upgrade module to it which will give you around 2,000 feet range and two way confirmation. The module is aftermarket but is designed to work with the factory remote starter.
sparky
Brad Eyben
Member - Posts: 33
Posted: February 03, 2008 at 10:15 AM / IP Logged
Thanks, do you know who makes this module? Or is it through GM?
turboneon
Member - Posts: 37
Posted: February 03, 2008 at 10:23 PM / IP Logged
http://www.bypasskit.com/product.aspx?prodid=XL2230
jwald
Posted: February 20, 2008 at 8:51 PM / IP Logged
The was kind of reference here:
https://www.the12volt.com/installbay/forum_posts.asp?tid=93791&get=last
http://tinyurl.com/3bpxvl
But I a have questions as well. It shows that it comes with the bypass module the xk01. Well that needs to be reprogrammed with proper firmware via a "bootloader" which appears to be another 100 and you have to have VIP software which I don't know if that is free. If someone has done this I would love some great detail. I have an 08 GMC Sierra 5.3L with factory remote that I would love to upgrade because they suck.
Chris Luongo
Platinum - Posts: 3,746
Posted: February 21, 2008 at 6:46 AM / IP Logged
jwald,
The bootloader is not free. I think it's like $50 or something like that. If you buy it, though, the software to operate it is free, at www.xpressdownload.com.
However, unless you're a professional installer or plan on doing a lot of cars, you shouldn't need to buy the loader.
If you can find a reputable seller who knows what they're talking about, and can answer your questions, you should be able to buy the product already loaded with the correct firmware for your car.
If you look around the forum, you might see some other members who've bought these products from random online discounters, and received the product with the wrong firmware installed.
If you can find a local shop in your area that sells this stuff, it might be worth paying extra to get it from them, because they'll have the loader to configure it properly for you.
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
