2008 honda civic si, python 871 xp alarm
sicivic13
Member - Posts: 26
Posted: April 23, 2008 at 2:47 PM / IP Logged
Does anyone know if the 2008 Civic Si has the same wiring as a 2006-2007 Civic? I need to install a Python 871XP and the only wiring schematic I can find is for a 2006 Civic. I am not planning on hooking up the remote start at this point in time. Does this mean that I would not need the immobilizer bypass module until I am ready to hook up the remote start?
Thanks.
Platinum - Posts: 12,488
Posted: April 23, 2008 at 8:03 PM / IP Logged
The information is the same. No need for the immobilizer bypass if no remote start is going to be installed.
sicivic13
Member - Posts: 26
Posted: April 24, 2008 at 7:55 AM / IP Logged
Thanks Jeff. I really appreciate the info.
sicivic13
Member - Posts: 26
Posted: April 28, 2008 at 2:22 PM / IP Logged
I finished installing a Python 871XP alarm in my 2008 Civic Si this past weekend. The only problem I have is with the range of the remote. It works great when I am away from the vehicle, but as soon as I get up close to the vehicle the remote ranges out about 75% of the time. I have the 2-way antenna mounted on the top of the windshield on the passenger side of the vehicle with the wire completely stretched out and run to the control module on the driver's side of the car. Does anyone have any ideas as to why this might be happening? I did replace the battery with several brand new ones and this did not solve the problem.
ya boy mike
Member - Posts: 44
Posted: April 28, 2008 at 10:03 PM / IP Logged
I have seen this happen on every 871XP i have ever installed. I think every time I install one and demo it for the customer and show them how it works I have to mash on the unlock button multiple times for it to turn off the alarm. For some reason those remotes just suck right against the vehicle.
Mike
It Hz
hurleyloser
Copper - Posts: 157
Posted: April 29, 2008 at 3:20 AM / IP Logged
make sure your antenna is mounted horizontally and excess cable is not looped, it's 771xv viper cousin also has issues with the unit not responding to commands right away.
sicivic13
Member - Posts: 26
Posted: April 29, 2008 at 7:41 PM / IP Logged
Thanks for the info guys. I appreciate the insight.
tedmond
Gold - Posts: 4,610
Posted: April 29, 2008 at 8:28 PM / IP Logged
also check your ground to the unit. a bad ground also messes up the range.
sicivic13
Member - Posts: 26
Posted: April 30, 2008 at 8:04 AM / IP Logged
tedmond you are the man. Sure enough it was not getting a good ground. Re-grounded it and it works great now.
Thanks.
sicivic13
Member - Posts: 26
Posted: April 30, 2008 at 8:10 AM / IP Logged
I have a 2008 Honda Civic Si with a Python 871 XP alarm that I installed. The question I have is do I need to install a hood pin? The wiring schematic I got from a 2006 Civic shows a hood pin wire (light blue) that comes off the fuse box but when you open the hood there is no light on the dashboard that comes on showing that the hood is open (similar to a door ajar warning light). I am trying to determine whether or not I need to go get a hood pin switch.
Page of 3
