viper responder 350 on 2004 mercury grand
hailstate
Member - Posts: 11
Posted: November 01, 2012 at 11:11 PM / IP Logged
Viper Responder 350 connecting to 2004 Mercury Grand Marquis without factory keyless entry
Only want to use siren, keyless entry, parking light flash and trunk release
Primary Harness H1
H1/1     Orange    (-) 500mA armed output (won't use)
H1/2     White  (+/-) Selectable Light Flash Input (Brown, pin 4@LCM)
H1/3     WHITE/ Blue        (-) 200mA Channel 3 Programmable Output
         (Press first to unlock driver and second to unlock all others)
H1/4     BLACK/ White       (-) 200mA Domelight Supervision Output (won't use)
H1/5     Green   (-) Door Trigger Input (?)
H1/6     Blue     (-) Instant Trigger Input (won't use)
H1/7     Violet  (+) Door Trigger Input (?)
H1/8     Black    (-) Chassis Ground Input (ground to chassis)
H1/9     Yellow (+) Switched Ignition Input (12+ switched from ignition)
H1/10   Brown   (+) Siren Output (connects to siren)
H1/11   Red      (+) Constant Power Input (constant 12+ from ignition)
H1/12   Red White          (-) 200mA Channel 2 Output (trunk release) (purple / YELLOW 5wi)
Door Lock Harness (No additional information in installation guide, refers me to Document No 1041 available only through dealer)
1     Light Blue       (-) Unlock, (+) Lock Output
2     Empty Not Used
3     Green (-) Lock, (+) Unlock Output
According to wiring diagram for car:
Power Lock without keyless entry the door locks are 5wi (reverse polarity)
With keyless entry they are postive trigger
Power Unlock is the same
Left Front Door Trigger (Blue is driver door trigger wire and BLACK/ orange is the three passenger doors. It says to use both wires and diode isolate each.) Would like to be able to hook H1/3 so I can press unlock once to unlock driver door and press again to unlock all remaining doors
Could someone clue me in to what I hook the door unlock to. Do I need relays? If I do I assume I will need one for trunk release too. I wanted to keep it as simple as possible because the domelight will come on with the door trigger, I don't need starter kill and I don't want to use any of the other options this can do. I just want flashing parking lights when i lock, unlock, the siren to work, of course the doors to be keyless and be able to pop my trunk from remote. I have a unlock, lock, axillary and "panic"? utton on remote
ANy help would greatly be appreciated
lurch228
Silver - Posts: 1,338
Posted: November 02, 2012 at 12:11 AM / IP Logged
There are conflicting wire lists so you will need to verify the right one.
MODEL YEAR(S)
GRAND MARQUIS   2003 -2004
KEY T-HARNESS IMMOBILIZER
FDKEY-6    N/A    FORD'S TRANSPONDER ANTI-THEFT SYSTEM, See NOTE #1
PART   COLOR LOCATION
12 VOLT CONSTANT   BROWN (+) and LIGHT GREEN (+)    @ IGNITION SWITCH HARNESS
STARTER RED / LIGHT BLUE (+)   @ IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 WHITE/ YELLOW (+) @ IGNITION SWITCH HARNESS
IGNITION 2 PINK/BLACK (+) @ IGNITION SWITCH HARNESS
IGNITION 3 N/A
ACCESSORY /HEATER BLOWER 1 GRAY / YELLOW (+)   @ IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2 BLACK/ GREEN (+)   @ IGNITION SWITCH HARNESS
KEYSENSE N/A
PARKING LIGHTS ( - ) WHITE/ BLACK (-)   @ LCM, GREY 16 PIN Plug, Pin 13, See NOTE #2
PARKING LIGHTS ( + ) BROWN (+)   @ LCM, BLACK Plug, Pin 4, See NOTE #2
POWER LOCK PINK / YELLOW (TYPE C), See NOTE #3   IN DRIVERS DOOR HARNESS
POWER UNLOCK PINK/LIGHT GREEN (TYPE C), See NOTE #3   IN DRIVERS DOOR HARNESS
DOOR TRIGGER DARK BLUE (-) and BLACK/ ORANGE (-) Use both, See NOTE #5   @ LCM Module, See NOTE #2
DOMELIGHT SUPERVISION DARK BLUE (-) (Requires #775 relay)   @ LCM Module, See NOTE #2
TRUNK RELEASE PURPLE / YELLOW, See NOTE #4   IN DRIVERS DOOR HARNESS
SLIDING POWER DOOR N/A
HORN DARK BLUE (-)   @ STEERING COLUMN HARNESS
TACH Any wire that is NOT RED or RED / LIGHT GREEN (AC)   @ IGNITION COIL or FUEL INJECTOR
WAIT TO START LIGHT N/A
BRAKE LIGHT GREEN (+)   @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM   N/A
ANTI-THEFT FORD'S TRANSPONDER ANTI-THEFT SYSTEM, See NOTE #1   @ IGNITION SWITCH TUMBLER
EXTRA INFORMATION
NOTE #1: This vehicle is equipped with a Special Anti-theft key, to remote start you will need a Bypass module 791, use this module IF you have a extra ignition key to place inside the 791 to remote start, if you do not have an extra key to use or wish not to have a key placed inside this bypass module, we OFFER a KEYLESS INTERFACE BYPASS MODULE that does not require a key to be placed inside the bypass module, this is Part # PKALL or PKFM, either one will work, to order, go to the INTERFACE BYPASS MODULE PAGE on this website. NOTE #2; the LCM (Lighting Control Module) is located to the right of the steering column. You can get to the harness of the LCM between the steering column and the LCM Module. NOTE #3: If vehicle is equipped with a FACTORY KEYLESS ENTRY System, then the vehicle has a TYPE B Door Locking System, vehicles without FACTORY KEYLESS ENTRY, have a TYPE C Door Locking System. Vehicles with the KEY PAD on the Door are considered to have KEYLESS ENTRY. NOTE #4: this vehicle uses a 5-wire TRUNK Release System that requires an extra relay part #775, to connect, See DIAGRAM NOTE #5: when connecting to an ALARM SYSTEM, use both DOOR TRIGGER wires and DIODE ISOLATE, to connect, See DIAGRAM
#500061: 2004 MERCURY GRAND MARQUIS 4DR SEDAN
Security
WIRE COLOR POLARITY LOCATION
Battery LT. GREEN/ VIOLET AND YELLOW (+) AT IGNITION SWITCH HARNESS
Ignition 1 WHITE/ YELLOW (+) AT IGNITION SWITCH HARNESS
Starter 1 RED / BLUE (+) AT IGNITION SWITCH HARNESS
All Door Trigger BLACK/ BLUE (+) AT UNDERDASH LIGHT
   THIS WIRE MAY ALSO BE FOUND IN DRIVER'S KICK PANEL.
Domelight Super BLACK/ BLUE (+) AT UNDERDASH LIGHT
LF Latch BLUE (-) AT MODULE TO RIGHT OF STEERING COLUMN
RF Latch BLACK/ ORANGE (-) AT MODULE TO RIGHT OF STEERING COLUMN
LR Latch BLACK/ ORANGE (-) AT MODULE TO RIGHT OF STEERING COLUMN
RR Latch BLACK/ ORANGE (-) AT MODULE TO RIGHT OF STEERING COLUMN
Trunk Trigger BROWN / WHITE (+) AT SWITCH IN TRUNK
Alarm Disarm BLUE/BLACK (-) IN DRIVER'S DOOR
Parking Lights WHITE/ BLACK (-) AT HEADLIGHT SWITCH
Convenience
Headlights-Lo RED / YELLOW (+) IGNITION SWITCH HARNESS
Wipers-Lo DARK BLUE/ORANGE (+) IGNITION SWITCH HARNESS
Trnk Release VIOLET / YELLOW (+) IN HARNESS IN DRIVERS KICKPANEL
Remote Start
Ignition 2 BLACK/ GREEN (+) AT IGNITION SWITCH HARNESS
Accessory 1 PINK/BLACK (+) AT IGNITION SWITCH HARNESS
Accessory 2 GRAY / YELLOW (+) AT IGNITION SWITCH HARNESS
   IF THERE IS A 2ND GRAY / YELLOW PRESENT YOU WILL HAVE TO ENERGIZE IT.
Anti-Theft Type FORD PATS SYSTEM
Anti-Theft Descript RF TYPE SYSTEM
Key Sense BLACK/ PINK (-) AT 6-WAY PLUG TO THE RIGHT OF STEERING COLUM
   THIS PLUG CONTAINS AIR BAG WIRES. PLEASE MAKE SURE THAT YOU DO NOT TAP INTO THEM.
Tachometer TAN/BLACK (AC) AT DRIVER'S SIDE FUEL INJECTOR
   YOU CAN ALSO US ANY OF THE UNCOMMON WIRES AT ANY FUEL INJECTOR.
Speed Sense GRAY/BLACK (AC) IN HARNESS IN DRIVERS KICKPANEL
Brake Lights GREEN (+) AT BRAKE SWITCH
Reverse Lights BLACK/ PINK (+) IN HARNESS IN DRIVERS KICKPANEL TO REAR
Horn BLUE (-) AT 6-WAY PLUG TO THE RIGHT OF STEERING COLUM
   THIS PLUG ALSO CONTAINS AIR BAG WIRE. PLEASE MAKE SURE THAT YOU DO NOT TAP INTO THEM.
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock PINK/GREEN (+) IN DRIVER'S DOOR
   VEHICLES W/O FACTORY KEYLESS HAVE REV POLARITY DOOR LOCK SYSTEM. WIRE IS THE SAME COLOR, INTERUPT WIRES IN DRIVER'S DOOR BOOT.
PowerLock PINK / YELLOW (+) IN DRIVER'S DOOR
   VEHICLES W/O FACTORY KEYLESS HAVE A REVERSE POLARITY DOOR LOCK SYSTEM. WIRE IS THE SAME COLOR, INTERUPT WIRE IN DRIVER'S DOOR BOOT.
Driver Mtr Unlock RED / ORANGE (+) IN DRIVER'S DOOR
Driver Mtr Lock RED / ORANGE (+) IN HARNESS IN DRIVERS KICKPANEL
DIRECTWIRE™ WIRING INFORMATION - MERCURY / GRAND MARQUIS / 2004 / Security
12volts brown and lt. green + ignition harness
Starter RED / lt. blue + ignition harness
Ignition WHITE/ yellow + ignition harness
Power Lock pink / YELLOW    driver kick, door harness
Notes: Without keyless entry the door locks are 5wi (reverse polarity). With keyless entry they are positive trigger.
Power Unlock pink/lt. green    driver kick, door harness
Lock Motor pink/black 5wi driver kick, door harness
Unlock Motor RED / orange 5wi driver door motor in door
Disarm Defeat pink/orange 5wi driver kick, harness to rear
Parking Lights+ brown + pin 4, blk plug @ LCM
Notes: The LCM (Lighting Control Module) is to the right of the steering column.
Parking Lights- WHITE/ black - pin 13, gry 16P plug @ LCM
Hazards same as turn signals
Turn Signal(L) lt. GREEN/ orange + steering column
Turn Signal(R) ORANGE / lt. blue + steering column
Door Trigger dk. blue and BLACK/ orange - LCM
Notes: Blue is the driver door trigger wire, it is in pin 11, gray 22 pin plug. BLACK/ orange is the three passenger doors, it is in pin 11, gray 16 pin plug. Use both wires and diode isolate each.
Dome Supervision use door trigger
Trunk/Hatch Pin BROWN / white - pin 5, gry 16P plug @ LCM
Hood Pin N/A
Trunk/Hatch Release purple / YELLOW 5wi driver kick, harness to rear
Notes: The fuel door release is WHITE/ pink (+) in the driver kick, harness to rear.
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer NOT red or RED / lt. grn ac any ignition coil or injector
Horn Trigger dk. blue - steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Posted: November 02, 2012 at 3:34 AM / IP Logged
Add a DEI 451 or a pair of relays* for your lock/unlock
You only need the green (-) door trigger, violet not used.
You will also need a relay AND diode (1N4004) across 85 and 86, band (cathode) to 86.
Wire as follows:-
Cut violet (or purple)** / YELLOW,
Front end to 87a.
Trunk end to 30.
H1/12 RED / white to 85
12V+ constant, fused at 15 amps to 86 and 87.
*It's far easier and neater to just plug in the 451 rather than use two relays and two diodes.
**I never know why some people call it violet, others purple they're both the same to me.
hailstate
Member - Posts: 11
Posted: November 02, 2012 at 4:31 PM / IP Logged
thanks boss, I may just break down and get the DEI 451 if I can find one at a local dealer.
lurch228
Posted: November 02, 2012 at 10:22 PM / IP Logged
To save yourself som time verify that the door lock wiring is not there sometimes they put it in and don't list the option as being there, so no remotes.
hailstate
Member - Posts: 11
Posted: November 02, 2012 at 10:42 PM / IP Logged
I sure will, I have about all the info to do this. If you hear a boom from central Mississippi then I didn't do something rightviper responder 350 on 2004 mercury grand -- posted image.
The funny thing is I did just about the same install about 5 years ago on a F-150. It was an Avital sytem with remote start. I think their install instructions were much more clear than the Viper install instructs are.
lurch228
Posted: November 03, 2012 at 12:06 AM / IP Logged
The manuals are leaving out what they consider information that a shop installer would already know as they don't want individuals doing their own installs anyways. The newer manuals for the 1-way systems either are vauge or leave out all together that they can be 2-way upgraded. IE buy a new 2-way system not upgrade the one you got equals more proffit for them.
hailstate
Member - Posts: 11
Posted: November 04, 2012 at 11:48 PM / IP Logged
Question. I will have 4 relays, one will be run off the yellow and orange of the wiring harness and is prewired. Can I run the one for parking light flash, trunk and doomlight supervision all off the same fused 12v power source. Literature says its best to come right from batteries to drive relays
lurch228
Posted: November 04, 2012 at 11:52 PM / IP Logged
For what you are trying to do you should be fine as they are low draw or pulsed outputs.
hailstate
Member - Posts: 11
Posted: November 05, 2012 at 12:07 AM / IP Logged
thanks very much, appreciate the quick reply. This tinkering is kind of fun
Page of 3
Friday, February 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
