04 Envoy XUV, XK01, Viper 5900
fplcman
Member - Posts: 20
Posted: October 27, 2006 at 8:54 AM / IP Logged
Group,
This is what I plan on doing:
Car: 2004 Envoy XUV
Alarm: Viper 5900SST (p/n 5301V) http://www.directed.com/security/viper/viper_responder_sst.asp
GM Interface: 455G
http://www.drdetailshop.com/455G.htm
 Window interface: 530T
http://www.drdetailshop.com/530T.htm
What I want to do:
Front Windows up/down
Rear Windows up/down
Middle Gate window: Up/down
Rear gate window: up/down
Rear roof: open/closed
Doors: lock/unlock
Heated seats on/off
Heater on/off
Relay for Ignition, Heater, Horn, Dome light, Light Flash, and heated seats (2) so 8 total.
Do I have this correct?
I need 2 530T for the front and Rear windows.
I need 1 530T for the Rear Gate window. (Can I use relays?)
I need 1 530T for the Rear roof. (Can I use relays?)
I need 7 relays
Or can I use Relays to make them open and close? How does a relay know when to stop if it is opening a window? The alarm timed output?
Also how do I get pass the rear roof sensors? The roof will not open unless the car is not moving and the back window is all the way down.
I found the roof wiring diagram here:
https://www.the12volt.com/installbay/forum_posts.asp?tid=60586
I found the Alarm wire Diagram here:
https://www.the12volt.com/installbay/forum_posts.asp?tid=47080
FplcMan
kgerry
Platinum - Posts: 3,455
Posted: October 27, 2006 at 9:20 AM / IP Logged
keep in mind you'll also need a bypass module for the passlock circuit... i would go with a 457G or 1700G instead of a 455G and 556L.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
fplcman
Member - Posts: 20
Posted: October 27, 2006 at 9:32 AM / IP Logged
I put the wrong one down... I want to go with the 457G
http://www.drdetailshop.com/457G.htm
Fplcman
fplcman
Member - Posts: 20
Posted: October 27, 2006 at 9:44 AM / IP Logged
Do I need to use the 456L Power Door Lock Interface or will the 457G take care of the doors?
Twelvoltz
Platinum - Posts: 2,384
Posted: October 27, 2006 at 10:46 AM / IP Logged
The 457G does door locks as well as passlock bypass.
fplcman
Member - Posts: 20
Posted: October 28, 2006 at 9:11 AM / IP Logged
Any more help on this? I need to find out how to wire the back window and roof... Thanks
FplcMan
Chris Luongo
Platinum - Posts: 3,746
Posted: October 28, 2006 at 1:48 PM / IP Logged
Is the moving roof already on the factory remote? Is there a button inside the car to control the roof? Is it a one-touch button, or do you have to hold it? Does it work even when the ignition is off?
The 457G isn't terribly good. It doesn't give you driver's-priority unlocking, or domelight turnon, or permiter lighting.
The GM-DLBP from bypasskit.com will open only the driver's door first if you want it to. It will also turn on the domelight and exterior lights when unlocking.....but only when the engine is off.......so basically you'd have domelight supervision, except when the remote starter is running.
bypasskit.com also has another bypass module, which I think is the XK07, and it automatically activates the defroster and seat heater when it is very cold.
kgerry
Posted: October 28, 2006 at 1:57 PM / IP Logged
XK01.... and BTW, the new 1700G which replaces the 457G does drivers door only and trunk, perimeter lighting, etc, etc.....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
fplcman
Member - Posts: 20
Posted: October 28, 2006 at 2:18 PM / IP Logged
Chris,
The only thing on the factory remote is the back window down (Not up). You do have to have the key in and turned to have anything work, The car does not need to be on.I have 4 buttons overhead… One for the sun roof, one for the middle window, one for the Back window, and one for the roof. The roof requires the back window to be down and the car not to be moving. You do have to hold the button down to get the back windows down unless you use the remote. You then have to hold down the roof button to open the roof. After the roof is open you can not put the back window up unless you close the roof.
Here is the wiring Diagram that I found on this site…
https://www.the12volt.com/installbay/uploads/endgate.gif
Thanks for your help.
Fplcman
fplcman
Member - Posts: 20
Posted: November 04, 2006 at 9:19 PM / IP Logged
I just purchased the viper 5900. I am waiting for my XK01 to show up but I have a question.
The XK01 wiring:
http://www.bypasskit.com/Manuals/XK01_AMDL%20%20D17_I_EN.PDF
I have a 2004 Envoy Type 1 vehicle.
This is the question:
The only wire listed as a anti-grind/ground is on the Relay satellite ribbon harness. Do I cut this wire and connect it to the brown wire on the XK01?
On the XK01 both the Green (Lock) and blue (unlock) wire has a – sign next to it. The door Lock on the 5900 has Green wire with (–) lock (+) unlock and Blue wire with (+) unlock (-) lock. Do I just connect the Blue to Blue and Green to Green or do I need a relay to switch them around?
The door sense Trigger on the XK01 is a -. The 5900 input is a +. Do I need to use a relay to switch them?
FplcMan
Page of 4
