remote start, 1994 mazda rx7
katit
Member - Posts: 37
Posted: April 03, 2008 at 9:17 AM / IP Logged
First of all, please excuse me for this questions as I beleive it was asked million of times :) But I did search and still want suggestion from pro's
I have 94 Mazda RX7 and I want to install remote start/keyless on this car. I will need trunk pop also. I think I figured all details on installation of actuators and I'm good with theory. No problem getting relays/etc working. I had bulldog remote start installed on my Civic long time ago.
This is my toy car and I do everything myself. Giving it to the pro is not an option because I won't let anybody except me to touch a car (or I have to watch) and I like to do and learn myself. Cars is my hobby. So, time spent will be ejoyable. I also have no problem installing remote start on manual car as I plan on wiring it correctly for neutral switch. I also will wire it for parking brake switch.
Ok. Now to the questions.
1. How come DIY person can't get better quality units? DEI? Or Compustar? I talked by many people and they like DEI. Reading though this forum - people like Compustar PRO. One guy that used to be installer said that Audivx Prestige is not bad cheaper alternative.
2. So far I found 2 systems I can get online and I think suit my needs. a.Audiovox Prestige APS687($65) or b. VIPER 571XV ($65)
Viper seem to be better feature-wise but size of remote worries me. It needs AAA battery! Viper 160xv is "my size" but there is none for sale. I'm looking at that price range (~$50-70) with basically start and keyless. Bigger range helps. I need reliable unit.
What do you think is good choice for me? I want higher end brand for reasonable price with smaller remote.
Thanks in advance
Twelvoltz
Platinum - Posts: 2,384
Posted: April 03, 2008 at 10:33 AM / IP Logged
Compustar, Audiovox, DEI are all quality units. It really depends on the features you want and personal preference. My preference is DEI products but it's probably more because I no longer need to read the manual than anything else. Just to throw something at you, as you are aware I am sure DEI makes many different brands. The 160XV you are talking about is the same exact unit as the Valet 562T and the Avital 4200 with different labels/remote design. The Valet and Avital might be easier to find online than the Viper branded stuff.
katit
Member - Posts: 37
Posted: April 03, 2008 at 10:37 AM / IP Logged
Good info. I will check those other brands. Remote design is important. I like something OE looking and smaller. Like that Viper I mentioned.
2-way feature seems good to me, but payback is bigger remote if I understand correctly.
Also, is there unit (no alarm) that has remote start and turbo timer?
skee-weezy
Copper - Posts: 177
Posted: April 03, 2008 at 10:50 AM / IP Logged
most systems w/the remote start option can be configured as a turbo timer.... after connecting the remote start portion most times u just have to enable this feature from inside the unit's programming menus....i've seen some people just substitute the valet takeover option instead too.....
there can be only one.......
skee-weezy
Copper - Posts: 177
Posted: April 03, 2008 at 10:52 AM / IP Logged
oh yeah.. im amazed no one mentioned code-alarm too... they are pretty easy to install too.... and oh yeah.. for those of u that may have never worked with the two recently.....CODE and AUDIOVOX are now virtually identical on most models... kinda like the viper and python brands for DEI
katit
Member - Posts: 37
Posted: April 03, 2008 at 10:57 AM / IP Logged
I don't really need alarm. I have factory alarm and it does fine. I will have to wire too arm/disarm it, but I can do it from door actuator even if system I get do not support it
tedmond
Gold - Posts: 4,610
Posted: April 03, 2008 at 3:02 PM / IP Logged
stick with DEI, compustar, autopage or even audiovox units (codealarm) they are all very good and reliable. The only thing is, audiovox manuals are hard to read.
dswift
Copper - Posts: 396
Posted: April 03, 2008 at 6:16 PM / IP Logged
Well just keep in mind that the compustar has a built in turbo timer. Just make sure you connect the e.brake wire during the install.
"dont ground out!"
katit
Member - Posts: 37
Posted: April 03, 2008 at 6:36 PM / IP Logged
It's all good about compustar. But they not available to me to buy.
katit
Member - Posts: 37
Posted: April 03, 2008 at 9:32 PM / IP Logged
Does Viper 571xv come with 2 different remotes? It shows so on main page but it shows 2 bigger remotes on detail page on website.
If it's got smaller remote included, what is limitation of it? I like look/feel and would get that system if they had smaller remote in box.
Page of 4
Tuesday, November 11, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
