the12volt.com - Free Technical Information for Mobile Electronics Installers since 1999
the12volt.com - Free Technical Information for Mobile Electronics Installers, Enthusiasts, and Do-It-Yourselfers since 1999 Recommended Tools for the Shop and Installer
BasicsCar AudioCar SecurityCruise ControlsDiodesDoor LocksOhm's LawPassive CrossoversRelaysResistorsSubwoofer Enclosures Search
Application GuidesCalculators, Charts, DiagramsDownloads/ManualsFind InstallersForumsGlossarySubwoofer WiringToolsVehicle Wiring Recent Topics
Diodes
Glossary of Terms
Ohm's Law
Relays
Resistors
Tools and Equipment
Wire Sizes
Introduction
Metra Application Guides
Parallel & Series Calcs
Passive Crossovers
Port Length Calculators
Subwoofer Box Calculators
Subwoofer Enclosure Types
Subwoofer Wiring Options
Thiele - Small Parameters
Miscellaneous
Relay Diagrams
Vehicle Wiring Database
Introduction
Alarm Accessories
Alarm Modules
Alarm Sensors
Basic Connections
Illuminated Entry
Light Flash
Power Door Locks
Starter Interrupts
Pictorials
Relay Diagrams
Introduction
Electrical Connections
Mechanical Connections
Servo Settings
VSS and Tach Info
Vehicle Wiring Databse
All Forums
Buy & Sell Equipment
Car Audio
Car Audio Hot Topics
Car Security & Convenience
Car Security Hot Topics
Car Security Pictorials
Cellular & Communications
Cruise Controls
Employment
Fiberglass & Fabrication
General Discussion
Lights, Neon, LEDs, HIDs
Miscellaneous
Mobile Video & Navigation
Motorcycle Electronics
Music, Favorite Songs
Relays
Rides & Systems Gallery
Vehicle Information
Recent Forum Topics
Forum Help & How To
Forum & Site Notices
Books & DVDs
Calculators
Charts
Diagrams
Downloads - Manuals
Find an Installer
Forums - Q&A
Glossary of Terms
Insurance for Car Stereos
Links
Mobile Tech News
Relay Diagrams
The Application Guide
About the12volt
Hurricane Katrina
Link to Us
Support Us
TopGearAutosport.com
GPS Vehicle Tracking
Relay Diagrams - Door Locks - Actuators / Reverse Polarity - Negative Switch/Trigger (a)
If you need a diagram that is not included in the 65 relay diagrams shown here, please post your request in our forums.
Diagram URL to include in your forum posts:
This is practically identical to the 5 wire alternating 12V(+) system. The only difference is there's no switch. Both motor legs rest at ground at the relays. To lock or unlock the vehicle, polarity is changed on one motor leg via a negative pulse to the coil of the respective relay.
Relay Diagrams - Quick Reference (Last Updated: 5/7/2011)
Connecting Additional Devices to the Remote Turn On Wire
Constant to Momentary Output - Negative Input/Negative Output
Constant to Momentary Output - Negative Input/Positive Output
Constant to Momentary Output - Positive Input/Negative Output
Constant to Momentary Output - Positive Input/Positive Output
Convert a Negative Output to a Positive Output
Convert a Positive Output to a Negative Output
Door Locks - 3 Wire Positive
Door Locks - 4 Wire Reversal
Door Locks - 5 Wire Alternating 12 Volts Positive
Door Locks - Actuators / Reverse Polarity - Negative Switch/Trigger (b)
Door Locks - Actuators / Reverse Polarity - Positive Switch/Trigger
Door Locks - Add Auto Lock without an Alarm or Keyless Entry System
Door Locks - Add Auto Unlock without an Alarm or Keyless Entry System
Door Locks - Dodge Caravan (1996 - 2000)
Door Locks - Dodge Caravan (2001 - 2005)
Door Locks - Ford Probe
Door Locks - Nissan Maxima 1995 - 1997, Double Ground Pulse Relay Diagram
Door Locks - Nissan's Single Wire '91-'95 using 1 relay and 1 diode (Type F door lock)
Door Locks - Nissan's Single Wire '91-'95 using 2 relays (Type F door lock)
Door Locks - Single Pulse to Lock and Unlock - Negative Pulse
Door Locks - Single Pulse to Lock and Unlock - Positive Pulse
Door Locks - Toyota with Child Safety Door Lock System
Door Locks - Vacuum Type
GM Vehicle Anti-Theft System - Passkey
GM Vehicle Anti-Theft System - Passkey II
Headlights and Parking Lights on with Wipers - Negative Input/Positive Output
Headlights and Parking Lights on with Wipers - Positive Input/Positive Output
Illuminated Entry for Vehicles with Negative Door Triggers
Illuminated Entry for Vehicles with Positive Door Triggers
Latched On/Off Output Using a Single Momentary Negative Pulse - Positive Output
Latched On/Off Output Using a Single Momentary Negative Pulse - Positive Output - No Diodes
Latched On/Off Output Using Two Momentary Negative Pulses - Negative Output
Latched On/Off Output Using Two Momentary Negative Pulses - Positive Output
Latched On/Off Output Using Two Momentary Positive Pulses - Negative Output
Latched On/Off Output Using Two Momentary Positive Pulses - Positive Output
Latched Output - Momentary to Constant Output - Negative Input/Positive Output
Latched Output - Momentary to Constant Output - Positive Input/Positive Output
Light Flash - Basic - Negative Input/Positive Output
Light Flash - Two Wire (German Vehicles) - Negative Output from Alarm/Keyless Entry
Light Flash - Two Wire (German Vehicles) - Negative Output from Alarm/Keyless Entry (Dual Make SPST Relay)
Light Flash - Two Wire (German Vehicles) - Positive Output from Alarm/Keyless Entry
Light Flash - Two Wire (German Vehicles) - Positive Output from Alarm/Keyless Entry (Dual Make SPST Relay)
Light Flash - Two Wire (German Vehicles) - Weak Negative Output from Alarm/Keyless Entry
Light Flash - Using Siren Output
One Channel to Multiple Outputs
Pulsed to Steady Output (Turn signal output to steady output for duration of turn signal)
Radio On Until Door Opened (Retained Accessory Power) - Negative Door Trigger
Radio On Until Door Opened (Retained Accessory Power) - Positive Door Trigger
Remote Start Relay Diagram - Basic Only
Starter Kill - Normally Closed
Starter Kill - Normally Open
Starter Kill - Passive with Horn Output and Horn Interrupt
Starter Kill - Passive with Remote Turn On Lead
Starter Kill - Passive with Switch
Stereo to Bridged Mono Switched Outputs
Switching from Series to Parallel and Back
Switching from Stereo to Bridged Mono and Series to Parallel
Weak Negative Output to Strong Ground Output
Weak Positive Output to High Current Positive Output
Wigwag Flashing Lights - Negative Input/Positive Output
Wigwag Flashing Lights - Negative Input/Positive Output - Isolate Left and Right Lights
Wigwag Flashing Lights - Positive Input/Positive Output
Wigwag Flashing Lights - Positive Input/Positive Output - Isolate Left and Right Lights
Relays:
SPDT and SPST Automotive Relays
Converting Polarity
Starter Interrupts
Door Locks
Illuminated Entry & Light Flash
Special Applications
Relays Forum
ohm's law, resistors, relays, and more
Custom Search
Follow the12volt.com: Follow the12volt.com on Facebook Follow the12volt.com on Twitter Follow the12volt.com on Google +
Share, print & email this page:
Thursday, May 24, 2012 Copyright © 1999-2012 the12volt.com Donate to the12volt.com Privacy Policy Advertising Free Sitemap Generator
the12volt.com - Free Technical Information for Mobile Electronics Installers, Enthusiasts, and Do-It-Yourselfers since 1999 Donate to the12volt.com
